JanneI
Merging/stitching images
I am working with multiple image tiles which I need to compile into single bigger image. This question has been asked earlier eg:
Is it possible to combine two pictures in one expression column?
Generic solution is to use H/V List Boxes. Here, my problem is that merged image has white line between the images which I don't want to have. Is there any way to modify List Box style not to have borders? Or some other method to do merging?
Janne
Re: Merging/stitching images
In JSL, that looks like this. Not sure what the performance will be, I don't think it will be using many CPUs.
img = Open("$SAMPLE_IMAGES/windmap.png", "png")<<getpixels;
compose = 	(img||img||img)|/
			(img||img||img)|/
			(img||img||img);
outpic = newimage(compose);
new window("no gaps", outpic);
|| is the horizontal matrix concatenation and |/ is vertical. Line 1 turns the image into a matrix.
Not sure how good idea this is, but maybe you can play around with negative margins (if all images are same size)
img = Open("$SAMPLE_IMAGES/windmap.png", "png");
nw = New Window("",
	Lineup Box(N Col(3),
		img,img,img,
		img,img,img,
		img,img,img
wait(2);
pbs = nw << XPath("//PictBox");
pbs << Margin(Left(-2), Top(-2));
Also for me it seems like there are no borders between images. Are all the images you have same size?
nw = New Window("no borders",
	V List Box(
		h list box(img,img,img),
V List  Box + H List Box (no borders):
Lineup Box() (borders):
JanneI
Jarmo, You are amazing!
With your help, I was able to study this more. Apparently the issue is not originating from List boxes but from Get Picture-function. With this, borders appear to resulting picture object. However, I would like to be able to convert the List to Picture as then further manipulation (eg cropping) is possible.
So, any ideas how to get Picture without borders?
v_list_box = V List Box(
outpic = v_list_box << Get Picture;
new window("with borders", outpic);
new window("no borders", v_list_box);
JanneI
Hi All,
Apparently there is no trivial solution to get of borders caused by the Get Picture function. Likely there are many other work arounds but I ended to do this by using Python and sharing this here if anyone has interest to this. Something like below
Python Init();
Python Submit( "\[
import cv2
import datetime
path = r'C:\Program Files\SAS\JMP\16\Samples\Images\windmap.png'
img=cv2.imread(path)
img_concat = cv2.vconcat([
cv2.hconcat([img, img, img]),
cv2.imwrite(r'C:\tmp\final_image.png', img_concat)
str='Concationation completed'
getStr = Python Get( str );
show(getStr);
Python Term();
outpic = Open("C:\tmp\final_image.png",png);
new window("no borders", outpic);
outpic = empty();
Here, OpenCV library (cv2) is used which works well in my case as I have thousands of big pictures to be processed. OpenCV support utilization of GPU which reduce execution time drastically (several hours in my case).
			(img||img||img)|/
			(img||img||img);
JanneI
I did some testing for the performance. Getpixels - matrix concatenation method is three times faster than List box - Get Picture method. And no borders between the tiles. Very good advice. Thanks Graige!
