wgardnerQS
Response Screening Effect Size - logistic
Related to the previous post How to get "Effect size" column with Response Screening functionality , I am also wondering how effect size in the response screening platform is calculated, specifically for categorical Y vs continuous X.  JMP help shows:  "When Y is categorical and X is continuous, the effect size is the square root of the average ChiSquare value for the whole model test."  Running below script on BigClass yields effect sizes of 0.37082 and 0.16935 for height and weight, respectively.  How does effect size^2 relate to ChiSquare?
Response Screening(
	Y( :sex ),
	X( :height, :weight ),
	PValues Table on Launch( 0 ),
		Dispatch( {"Response Screening"}, "", TabListBox, {Set Selected( 2 )} )
0 REPLIES 0
