Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
chandankishor66
Merge rows and get infrimation in signal row
Hello JMP community,
How to merge multiple rows with the same name and obtain its value in a single row.
Regards,
Chandan
Re: Merge rows and get infrimation in signal row
Assuming there's only one valid entry for each column in each batch number (this might be an invalid assumption), you could use the tabulate function to create a new table. Simplified example below:
pauldeen
Stack your last 4 columns using the Batch # as the group variable.
In the new table, right click the empty cells and delete the rows containing empty cells.
Split your table again using Batch as the group.
Stack:
Select empty cells:
Delete rows:
Split:
Result:
pauldeen
Stack:
Select empty cells:
Delete rows:
Split:
Result:
