Having just recently taught statistics in the Psychology Department, I became aware of their frequent use of the terms moderation and mediation. Moderation appears to be just another term for two-factor interactions. However, mediation is quite different. It is defined as a situation when the relationship between a predictor variable and outcome variable can be explained by their relationship to a third variable (the mediator)..I was able to "salvage" a little bit of my ego by using SPSS, as was suggested previously.
I wonder if JMP might add these two terms into the JMP vocabulary and possibly increase its usage by those in the psychology and maybe even medical fields?
