Jackie_
Extract data table tile
HI,
I want to extract data table tile and store in the list. I tried get data table list function and was able to store the data table names but the sting contains Data table ("Title"), I only want to store title not the data table().
Open( "$SAMPLE_DATA/Big Class.jmp" );
Open( "$SAMPLE_DATA/Cars.jmp" );
list = Get Data Table List();
title =
Re: Extract data table tile
This will get you what you want
For Each( {value, index}, list,
	list[index] = Word( 2, Char( value ), "\!"" )
You can use <<Get Name() on the data table reference to get the table name. To get names of all datatables you can use
tablenames = Get Data Table List() << Get Name();
Since the data table references are stored in a list, you can send the << Get Name message to the list and it will distribute the send to each item. The result is a new list of the names.
table = Get Data Table List();
name = table << Get Name;
Lists and matrices offer the opportunity to 'vectorize' operations by allowing functions and messages to work on the collection as a whole without the need for explicit iteration in JSL.
