LBrian
Make error message
Hi, All.
I want to make an error message 'No item' window.
I made a script. but, it has not worked.
Please check my script where is wrong.
dt = Open( "$Sample_Data/Blood pressure.jmp" );
dt<< show window( 0 );
win = New Window( "Select Item(s) for drawing the Histogram",
		<<Modal,
		Text Box( "Item List" ),
		H List Box(
			allcols = Col List Box( dt, all ),
			Lineup Box(
				2,
				V List Box(
					bbAdd = Button Box( "Add", xcols << append( allcols << get selected ) ),
					bbRemove = Button Box( "Remove", xcols << remove selected )
				xcols = Col List Box( "Numeric", <<Modeling Type( {"Continuous"} ), min items( 1 ) ),
			V List Box(
				bbOK = Button Box( "OK",
					xvar = (xcols << Get Items);
					str = "";
					show(xvar);
					if(xvar == "{}",
					Throw("No item")
					For( i = 1, i <= N Items( xvar ), i++,
						str = str || "Continuous Distribution(Column(:Name(\!"" || xvar[i] || "\!"))),"
					Eval( Parse( "dt << Distribution(stack(1)," || str || ");" ) );
					win << Close Window;
				bbCancel = Button Box( "Cancel", Throw() )
Thanks.
tom_abramov
Re: Make error message
add error window message in case of zero column added:
		//<<Modal,
		H List Box(
			Lineup Box(
				2,
				V List Box(
			V List Box(
					str = "";
					show(xvar);
					if(NItems(xvar) == 0,
					ErrWin = New Window("Error",<<modal, Text Box( "\!NPlease add columns\!N\!N" ))
					,//else
					);//end of if
tom_abramov
		//<<Modal,
		H List Box(
			Lineup Box(
				2,
				V List Box(
			V List Box(
					str = "";
					show(xvar);
					,//else
					);//end of if
LBrian
Thank you very much!!!!
