qspringleaf
How to change "quantiles distribution" Summary Page
How to change "quantiles distribution" Summary Page marked yellow. from current summary to a new one (summary use 1% a step), then can get more detailed distribution.
Re: How to change "quantiles distribution" Summary Page
By golly, there is an option to do this.  Click on the red triangle and go to
      Display Options==>Set Quantile  Increment
Enter in .01, and you will get the results you want.
Thanks for the response.....it made me look.......one learns something new about JMP every day
The below script works, but there is an option under the red triangle
Here is an example on how to do that
dt = Open( "$SAMPLE_DATA\semiconductor capability.JMP" );
dis = dt << Distribution( Continuous Distribution( Column( :NPN1 ) ) );
percentiles = {};
knowns = {};
values = {};
For( i = 100, i >= 0, i--,
	Insert Into( percentiles, Format( i / 100, "Percent", 6, 1 ) );
	If(
		i == 100, Insert Into( knowns, "maximum" ),
		i == 75, Insert Into( knowns, "quartile" ),
		i == 50, Insert Into( knowns, "median" ),
		i == 25, Insert Into( knowns, "quartile" ),
		i == 0, Insert Into( knowns, "minimum" ),
		Insert Into( knowns, "" )
	Insert Into( values, Col Quantile( :NPN1, i / 100 ) );
newTableBox = Outline Box( "Detailed Quantiles",
	Table Box(
		String Col Box( "", percentiles ),
		String Col Box( "", knowns ),
		Number Col Box( "", values )
report( dis )["Quantiles"] << Append( newTableBox );
report( dis )["Quantiles"] << delete;
qspringleaf
thanks for suggestion, do have tips that work by changing setting instead of script? many thanks
qspringleaf
thanks, it works well.
