TWE
TWE
Loop and concatenate
I need a data table which creates random values in a column and concatenates the rows vertically. So far the script overwrites the columns but I need the final data table with 5xn rows including random values.
n=0; // counter
dt = new table("Test", add rows (5), new column("Random", numeric, continuous, formula(random uniform(0,6))), new column("Incr", numeric, continuous));
startwork = Function( {},
dt << add rows (5);
:random << formula(random uniform(0,6));
:Incr << formula(n);
n+=1;
if(n<10, Schedule(5, startwork() );
	Schedule( 0, 0)
startwork();
Thanks for any help
Re: Loop and concatenate
There isn't a need to reset the formulas for each scheduled event.  So try the code below, and I think it might be what you need
dt = new table("Test", new column("Random", numeric, continuous, formula(random uniform(0,6))), new column("Incr", numeric, continuous,
	formula( If(mod(Row(),5)==0,x=floor(Row()/5)-1,x=floor(Row()/5));x))
n=0; // counter
dt << add rows (5);
n+=1;
	Schedule( 0, 0)
startwork();
n=0; // counter
dt << add rows (5);
n+=1;
	Schedule( 0, 0)
startwork();
TWE
TWE
Thank you very much, this works fine!
