AsymptoticCos
Locking all columns in JMP
How do I lock all the columns in my JMP table with JSL?
Re: Locking all columns in JMP
Here is a simple example
for(i=1,i<=ncols(dt),i++,
	column(i)<<lock(1)
Look in the Scripting Index for description and examples.
	column(i)<<lock(1)
You can also do this interactively.
Select all your columns, right click, standardize attributes
From Attributes select lock
Enable Lock, press Apply, verify from column list columns are locked and press OK
JMP will also create a script to do this but it isn't as robust as the script provided by Jim (JMP created one has pre-determined columns in a list)
Local({old dt = Current Data Table()},
	Current Data Table(Data Table("Big Class"));
	For Each({col, index}, {:name, :age, :sex, :height, :weight}, col << Lock(1));
	Current Data Table(old dt);
AsymptoticCos
How do you see this JMP created script?
You have to have Log mode as Enhanced (I think this might be enabled by default since JMP JMP16/17+?)
Then you can open the Log (press Ctrt+Shift+L or View/Log).
