metazeta
graphing s-parameters in dBm using s2p (touchstone) file
I'm new to JMP, using version 15.2.1 and trying to graph s-parameters for a Power Amplifier using an .s2p (touchstone) file exported from a Rohde & Schwarz network analyzer. I'm using the sNp file importer add-in which creates the data table, but when I try to setup my graph for power vs. frequency, my results don't look as expected. Any suggestions? Thank you.
Re: graphing s-parameters in dBm using s2p (touchstone) file
What does "results don't look as expected" mean in your case?
