AsymptoticCos
Lock a column in script while working with multiple tables with same column names
I have three tables I am working with in my JSL. I am calling these dt1, dt2, dt3.
dt1 has the columns A, B, C, D
dt2 has the columns B, X, Y, Z
dt3 has the columns D, Q, R, S
I want to lock B in table dt2. How do I do that? The usual ":B << lock (1)" script is locking B in dt1.
Re: Lock a column in script while working with multiple tables with same column names
If you don't tell JMP which table to use, it uses current data table -> use more robust method of referencing to your column (add datatable reference). Column(dtref, colname) is my preferred method
Column(dt, "Age") << Lock(1);
You could also use dt:Age
dt:Age << Lock(1);
Edit:
From Scripting Guide check out Scripting Guide > JSL Building Blocks > Rules for Name Resolution > Scoping Operators
dt:Age << Lock(1);
Edit:
