BookmarkSubscribe
fidaleom
Lo and Hi limits in Contour Profiler
Hello dear All,
I designed and experiment with multiple responses with response limits. When I use the contour profiler I do not see pre-set values for Lo limit and Hi limit corresponding to response limits. I read that I have to define Spec limits and those limits directly appear as Lo and Hi limits in the contour profiler. This requires extra work, especially when there are many responses. Is there a way to tell JMP to pre-set Hi and Lo limits in the contour profiler by taking them from response limits? Response limits are introduced when designing the experiment so they are already there.
Furthermore, when we use the save column/prediction formula in the analysis of a response (Fit model platform) is it possible to store in the column also the response limits or the spec limits of the response that was fitted to the data?
Many thanks,
Marcello.
