Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
Dennisbur
Limits in graph Builder
Hello
Sometimes I use limits in graph builder, which shows me the limit lines on the graph
but I didn't find the option to show me the number of limits (minimum and maximum) in this graph.
Can you address how I can show the number of the data of the limits on my graph?
Re: Limits in graph Builder
One more option is to use float bar chart (or line chart) for the limits
Ressel
I think, if you could share a copy of a data table including the graph builder table script, that would be really useful.
ian_jmp
Does the '5 Number Summary' give you what you want?
Dennisbur
Hello Ian,
It's not assisting me because I needn't a plot box.
For example, I have a lot of test names, and each test name has its own limit.
Actually, I have found the option to add limits lines by graph builder > interval
But the graph just adds limits lines and not the info of LO_LIMIT and HI_LIMIT on these lines.
I will very much appreciate it if you can address me where I can add the info to my graph which limits it is?
ian_jmp
OK. So is this the kind of thing you are after, please?
If so, you can get it with a graphics script that uses 'HLine()' appropriately. Run this code, then right click on the FrameBox() of Graph Builder, select 'Customize . . .' then pick 'Spec Limits' from the list on the left:
NamesDefaultToHere(1);
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
gb = dt << Graph Builder(
				Variables(
					X( :NPN1 ),
					X( :PNP1, Position( 1 ) ),
					X( :PNP2, Position( 1 ) ),
					X( :NPN2, Position( 1 ) )
				Elements( Box Plot( X( 1 ), X( 2 ), X( 3 ), X( 4 ), Legend( 10 ) ) ),
					Dispatch(
						ScaleBox,
						{Min( -6.61851837529382 ), Max( 828.849379963722 ), Inc( 200 ),
						Minor Ticks( 3 )}
					Dispatch(
						"Graph Builder",
						FrameBox,
						{Add Graphics Script(
							3,
							Description( "Spec Limits" ),
							Pen Color( "Red" );
							// Parameter 1
							H Line( -0.5, 0.5, 100 );
							H Line( -0.5, 0.5, 200 );
							// Parameter 2
							H Line( 0.5, 1.5, 80 );
							H Line( 0.5, 1.5, 600 );
							// Parameter 3
							H Line( 1.5, 2.5, 50 );
							H Line( 1.5, 2.5, 500 );
							// Parameter 4
							H Line( 2.5, 3.5, 25 );
							H Line( 2.5, 3.5, 150 );
With a bit of work you could add the necessary graphics script programatically, reading values from the column properties or from a table like the one you show above.
