BookmarkSubscribeRSS Feed
revanda_retno0
Jul 11, 2016
JSL in PHP
Good Morning,
I'm a beginner in JMP and JSL.
How to execute JSL in PHP? is it possible if I process the JSL code inside PHP?
Thank you.
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
Re: JSL in PHP
The replies from msharp and PBZ are correct. JMP is not designed or licensed to be run behind a web server as you describe.
-Jeff
-Jeff
7 REPLIES 7
Phil_Brown
Mar 20, 2012
Re: JSL in PHP
As far as I know, PHP, Javascript, etc are interpreted and executed by the web browser. JSL requires JMP for interpretation and execution. Now, there are ways for a JSL script to run in JMP and produce PHP script code.
PDB
revanda_retno0
Jul 11, 2016
Re: JSL in PHP
if i want to create website and in the website have JSL code, is it possible?
Thank you for your answer.
msharp
Jul 28, 2015
Re: JSL in PHP
JSL is not a server side language.  So no, not really.
Phil_Brown
Mar 20, 2012
Re: JSL in PHP
I second what @msharp said. Just keep in mind that you need JMP to run JSL code.
PDB
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
Re: JSL in PHP
-Jeff
-Jeff
revanda_retno0
Jul 11, 2016
Re: JSL in PHP
yes. now i'm understand. Thank you so much.
ozkary
Community Member
May 29, 2018
Re: JSL in PHP
I think OLE automation can be used to do that. This however is only supported in certain languages like C# and VB.Net.
The code can run on the server side code to process the data and generate the charts which can then be send/stream back on the response.
Note that for this, we need a  server license.
