tom_abramov
JSL for "Configure levels"
Hi. I do not see any JSL command to set Axis levels (like x others).
Am I missimg something or the option doesn't exist in JSL?
Thank you
Re: JSL for "Configure levels"
Do you want to open the menu or set those by JSL?
Make a modification by hand and then check the report script. In this case I did changed value 12 label to be 13
Graph Builder(
	Transform Column(
		"age'",
		Ordinal,
		Set Property("Configure Levels", 1),
		Set Property("Value Order", {Custom Order({12, 13, 14, 15, 16, 17})}),
		Value Labels(
			{12 = "13", 13 = "13", 14 = "14", 15 = "15", 16 = "16", 17 = "17"}
		Use Value Labels(1),
		Formula(:age)
	Variables(X(:age')),
	Elements(Points(X, Legend(7)))
and it seems like it just creates a transform column and sets some column properties to it
tom_abramov
Thank you for your response.
There are this super useful options in "Configure Levels" like tail%, min count etc.
One can create a new column with formulas, but since the options already exist, please add JSL commands for them. Screenshot 2024-04-28 091846.png
If this is something you wish to see in JMP and there isn't yet a Wish List item about this, you can create one (https://community.jmp.com/t5/JMP-Wish-List/idb-p/jmp-wish-list).
