ChernoffTurtle7
how to input multi-selected cells at a time? (similar to 'Ctrl + Enter' in Excel)
Does anyone know how to input multi-selected cells within a column at a time in JMP? (similar to 'Ctrl + Enter' in Excel)
Thanks!
Re: how to input multi-selected cells at a time? (similar to 'Ctrl + Enter' in Excel)
I am not aware of being able to have multiple cell with keyboard entry in JMP.  However, if an item is copied into the paste buffer, and then multiple cells in a column are selected, the paste operation will paste the value into each of the selected cells
Click on a cell
Type in the value
CNTL+C on the cell
Select cells to be copied to
CNTL+V
Click on a cell
Type in the value
CNTL+C on the cell
CNTL+V
