uwe_hiss
JSL: Customize Control Chart
I would like to customize the control chart output like the screen below in my JSL script:
The settings in the prefrences and my script were not successful.
my biggest problem is, i can hide histogram and normal quantile plot and unhide the summary statistics only manualy-
Currently I'm working with the version 10.0.2
repWin = New Window( tableName, container = V List Box() );
For( k = 1, k <= N Items( dataColName ), k++,
	content = V List Box(
		dt_data_sub << Control Chart(
			Group Size( 1 ),
			KSigma( 3 ),
			Chart Col(
				dataColName,
				Individual Measurement( Test 1( 1 ), Test 2( 1 ), Test 3( 1 ) ),
				Moving Range,
				Capability(
					Distribution(
						Continuous Distribution(
							Column( dataColName ),
							Quantiles( 0 ),
							Summary Statistics( 1 ),
							Horizontal Layout( 1 ),
							Histogram( 0 ),
							Vertical( 0 ),
							Outlier Box Plot( 0 ),
							Normal Quantile Plot( 0 ),
							PpK Capability Labeling( 1 ),
							Capability Analysis()
				Dispatch(
					{"Individual Measurement of Assay"},
					"IR Chart of IM",
					FrameBox( 2 ),
					{Frame Size( 75, 162 )}
				Dispatch(
					{"Moving Range of Assay"},
					"IR Chart of MR",
					FrameBox( 2 ),
				Dispatch( {"Capability Analysis"}, "Long Term Sigma", OutlineBox, {Close( 1 )} ),
				Dispatch( {"Capability Analysis"}, "Control Chart Sigma", )
	container << Append( content );
Re: JSL: Customize Control Chart
If you do not want these elements in the platform, send the << Delete message to the display box responsible for the content to be removed. One way to identify the object is to right-click on the open-close button (triangle shaped icon) just to the left of an outline close to the information, then select Show Display Tree. So if I wanted to remove the Long Term Sigma as shown in your example, I would evaluate content["Long Term Sigma"] << Delete.
It seems, though, that you should be able to use launch options to disable the features that you mentioned, though.
JensRiege
This problem still continues in JMP 14.
Are there any plans to correct this?
