JMP scripting
I would like to script the conversion of results from a formula in a column to static numbers. Is that possible?
ian_jmp
Re: JMP scripting
If I understand correctly, you just have to delete the formula that generated the values (via the 'Column Info' dialog).
In JSL:
NamesDefaultToHere(1);
dt = NewTable("Test Remove Formula",
NewColumn("Values From Formula",Numeric, Continuous, Formula(RandomNormal())),
AddRows(10)
Wait(3);
Column(dt, "Values From Formula") << deleteFormula;
ian_jmp
Re: JMP scripting
In JSL:
AddRows(10)
Wait(3);
Re: JMP scripting
Thanks for pointing me in the right direction. I simplified your approach to
:Values From Formula << deleteFormula;
which worked like a charm.
As usual, the correct answer will come when the question is phrased correctly.
Re: JMP scripting
Your simplification should work great as long as JMP properly points to the correct data table.  I suggest that you scope the variable to ensure that there is no question as to what data table you are working with.
dt:Values From Formula << deleteFormula;
It is a good coding practice to remove the ambiguities.
Re: JMP scripting
Point taken. In this case is the house brand version of a script. It will never be shared or used by the outside world.
lwx228
Re: JMP scripting
Simple removal formula problem, I always find the master code to solve.thank you
