Sebastienlg
JMP SCRIPT: Creation of a graph based on a user selection variable
Hi all,
I would like to create a graph based on a user filter selection.
However, JMP doesn't recognize the variable "Y" choosen by the user, and an error occurs.
Here is my code:
Y = concat(Y,"  (ppm)");
graph = RAW_DATA_TABLE <<
				Control Chart Builder(
					Size( 534, 450 ),
					Show Two Shewhart Charts( 0 ),
					Sort by Row Order( 1 ),
					Variables( Y( :"Y" ),Subgroup( :Numéro de lot ), Phase(:"Period")),
					Get Limits(LIMIT_TABLE),
Does anyone have a suggestion to help me out with the naming of the Y ?
Thanks a lot,
Sébastien
Re: JMP SCRIPT: Creation of a graph based on a user selection variable
If you are sure that the column exists you could try wrapping the Y variable (I would use more descriptive variable name here) to Eval
y_column = Concat(Y, "  (ppm)");
graph = RAW_DATA_TABLE << Control Chart Builder(
	Size(534, 450),
	Show Two Shewhart Charts(0),
	Show Control Panel(0),
	Sort by Row Order(1),
	Variables(Y(Eval(y_column)), Subgroup(:Numéro de lot), Phase(:"Period")),
y_col = "Weight";
dt = Open("$SAMPLE_DATA/Quality Control/Coating.jmp");
dt << Control Chart Builder(Variables(Y(Eval(y_col)), Subgroup(:Sample)));
I'm not exactly sure what you are trying to do on line 1. Trying to build the column name based on something? How is Y chosen by user? Where does the "    (ppm)" come from?
Sebastienlg
The user selection is based on a list. However the selection made by the user from a list doesn't match with the datatable and I need to concatenate with "  (ppm)" in order to have the same variable name...
Then, I want to make the graph based on the "Y" concatenate with "ppm".
However, the "Y" is not recognize by the graph builder...
Do you have any suggestion to help me out with the naming of the Y ?
Thanks a lot for your answer
	Size(534, 450),
y_col = "Weight";
Sebastienlg
Great ! this is exactly what I need.
Now, I want to make a column selection based on the y_column to delete columns not desired by the user:
a = {Eval(y_colums)};
	limit_table << Invert Column Selection( a );
	limit_table << Delete Columns;
However, it does not work.
Do you have any idea to help me?
thank you
sebastien
The Column Dialog() command allows users to select columns for roles in later analysis. You should be able to delete/modify from the example from the scripting index to get what you need, i.e., just keep the things relating to the "Y" column.
pmroz
Line 1 of your code is not a good practice - you are redefining Y in terms of itself.
Try this:
raw_data_table = New Table( "Test",Add Rows( 4 ),
	New Column( "Col1  (ppm)", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [1, 2, 3, 4] ) ),
	New Column( "Numéro de lot", Character, "Nominal",
		Set Values( {"a", "a", "b", "b"} ) ),
	New Column( "Period", Numeric, "Continuous", Format( "Best", 12 ),
Y = "Col1";		// Selected from your dialog box
ycol = Y || "  (ppm)";
					Size( 534, 450 ),
					Variables( Y( column(RAW_DATA_TABLE, ycol) ),Subgroup( :Numéro de lot ), Phase(:"Period")),
//					Get Limits(LIMIT_TABLE),
 I commented out the reference to limit_table as I didn't have that data.
pmroz
