See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
JMP Exception! Error
natalie_
Hi all,
When I reopen a report, I sometimes get this error.  Why does this occur?
Re: JMP Exception! Error
Thank you, Jim for the response. This is absolutely correct. There is also an add-in, written by one of the members of our tech support team to help you report this issue and others like it in the future.
This is theCrash Report JMP Add-In that "is a JMP Add-In for Windows operating systems that will make it easy for you to submit crash information to JMP Technical Support."
Thank you very much for your desire to improve the reliability of JMP.
Connect with me on LinkedIn: https://bit.ly/3MWgiXt
You need to go directly to support@jmp.com to report this and to get resolution for it.
It is probably a bug in JMP.  When you contact technical support, they will need the error file (in the dialog) and, if possible, the files needed to reproduce the problem.  As Jim suggested, work with our technical support team on this.  Thanks for your help on this, and sorry it is causing a problem.   Craige
