BookmarkSubscribeRSS Feed
JMP Application Builder - Populating a List Box
abdulj
Jul 12, 2011
Hello
In application builder if I drop a String Col Box or List Box I know I can edit their contents in the properties pane on the right. The problem is that these contents are then hardcoded in. Is there a way to pass a list through the module's script to populate these values instead?
thanks
danschikore
Sep 21, 2012
Solution
For dynamic content, any property that is shown in the Property panel of App Builder also has a JSL-equivalent for setting the properties.  For the two boxes you mention these would be:
StringCol << Set({1,2,3,4});
List << Set Items({"First", "Second", "Third"});
From the Application Builder interface, if you right-click on any box and select "Scripting Help", it will take you to the section of the documentation that defines all messages than can be sent to objects of the selected type.
1 REPLY
danschikore
Sep 21, 2012
Solution
