Dennisbur
JMP 17
I recently upgraded to JMP 17, and I'm encountering a strange issue.
When I open the data table window on the full screen, the script JSL window also opens on the full screen.
Additionally, when I minimize the script JSL window, the data table window is also minimized.
How can I fix this and keep the windows at different sizes?
Re: JMP 17
I don't think I have heard this issue before. I think this might be something you should contact JMP support about.
Re: JMP 17
Such issues are best with Technical Support (email to [email protected]). Another option is (if you can) check if you have 17.0 installed (Help, About JMP) and update to 17.2. However, I'd check with Tech support first.
/****NeverStopLearning****/
Dennisbur
Re: JMP 17
maybe it will assist to somebody who will meet the same issue
To check the preference, choose File -> Preferences from the menu.  Next select Windows Specific in the list on the left.
