WoHNY
JMP 16: Script to open most recent .csv file in a folder.
I have been using the path = Pick File(); command to manually select the file to import into a data table. Can you script a command to import the most recent .csv file in a folder to a data table? There is only one worksheet in these files.
Re: JMP 16: Script to open most recent .csv file in a folder.
Did you search Functions in Help > Scripting Index and examine the File group of functions?
You could base a script on the Creation Date() or the Last Modification Date() functions.
WoHNY
Mark: Thank you for the response. I wasn't aware of the Scripting index under help so that is big help going forward. I was referencing a pdf version of a JMP15 Scripting Guide that is not search friendly. One issue I have with the file name is that it includes the time stamp at the end of the name, so it is dynamic. The format is FileName_YYYYMMDDHHMM.csv. I will stick with PickFile for now and experiment with the LastModificationDate function. Thanks again.
You can match the file name with the Contains() function if you want to ignore the time stamp.
I just happen to have had this need in the past, and luckily saved a script just in case...
You'll need to change the strings on line 2 and 3.
searchext = "jmp"; //extension to look for
searchfolder = "$DESKTOP"; //place to search
lstExtensions = {};
lstDates = {};
lstFiles = Files In Directory( searchfolder );
For Each( {i, j}, lstFiles,
	lstExtensions[j] = Char( Right( i, 3 ) );
	lstDates[j] = As Date( Creation Date( searchfolder || "/" || Char( i ) ) );
dt = New Table( "Files",
	New Column( "Name", character, set values( lstFiles ) ),
	New Column( "ext", character, set values( lstExtensions ) ),
	New Column( "Date", numeric, set values( Matrix( lstDates ) ) )
dt << Select where( :ext != searchext );
dt << Delete Rows;
newest = Col Min( :Date );
newfile = searchfolder || "/" || :Name[dt << Get Rows Where( :Date == newest )][1];
Close( dt, no save );
Open( newfile );
