Miof
Issue dealing with char to num
Hi Everyone
I am manipulating data, long strings of numbers stored as characters. I was able to break them down to the single numbers in their own column but something I cannot fix is happening.
Some numbers remain the same others are changing. An example of change is -8.7 turning into -8.6999999999999992894572642, this is screwing up the calculation and the comparison down the line. Round did not work.
Fact is when I save the data in CSV or TXT, these numbers are like they should be but when I am importing the file, the numbers in the table are ruined, This means JMP is doing something "wrong" by default.
Any idea how to fix that?
Thanks
Re: Issue dealing with char to num
Most likely issue with Floating Point Math (https://0.30000000000000004.com/) .
To what are you importing the files to and from where (which file type)?
Miof
I think I got the .... point. :)) .
That so the script needs to structured in a different way.
Ty
Miof
It is a csv but it happens with txt too.
