SDF1
Is there a way to fix the size of an OutlineBox?
Hi All,
  I have a script that pulls a data table and brings it into a window using the command dt<<Get As Report. This table has many columns and many rows. Unfortunately, it shows up in the window like this, it's really large and I don't want it to be this size:
  Instead, I'd like to resize it automatically, to something more like this:
  I found a thread here that is very similar to what I'm looking for, but not quite. I've tried sending commands like <<Set Max Size() or similar to the object that is the dt as a report, but then I don't get anything in my report window. I tried creating a Border Box(), but that doesn't work either.
  Any ideas/suggestions are much appreciated.
Thanks!,
DS
Re: Is there a way to fix the size of an OutlineBox?
I think you want to fix the size of table box, not outlinebox
dt = Open("$SAMPLE_DATA/Probe.jmp");
bb = dt << get as report;
// we need to modify the table box, not borderbox
(bb << child) << Set Scrollable(20, 5); // rows, columns
dt = New Window("test",
	Outline Box("Table",
		bb
		bb
SDF1
Hi @jthi ,
  Thanks for the quick response and solution. Yes, it was actually the table box I wanted to fix the size of, but nothing I had tried worked, so I thought maybe it was the OutlineBox. Anyway, great solution, thank you!
DS
One thing you might want to change is to change the reference to table box from
(bb << child)
to something like
bb[Table Box(1)]
as it might be more robust option (when building something like this, usually it is a good idea to almost always explore either properties or XML)
