Matheus_Plana
Is it possible to add a Brazilian Map in the Graph Builder (Map Shape)?
Hi, everyone!
I would like to send a report for my client with a different view of his data, coloring the Bralizian States in a Graph.
Do you know how can I add the Brazilian Map as a background map?
Thank you in advance!
Lean Six Sigma Master Black Belt, JMP Trainer
Byron_JMP
Re: Is it possible to add a Brazilian Map in the Graph Builder (Map Shape)?
if you can find a shape file, its fairly easy to add it.
https://www.jmp.com/support/help/en/17.0/index.shtml#page/jmp/example-of-creating-custom-maps.shtml
Byron_JMP
