lukasz
Invalid row number when accessing or evaluating of column values
Hello everybody,
after creating a new column Norm_Value I want apply formula to calculate relative values based on the position of "1" in the Base_value_norm column:
		dt << New Column( "Norm_Value",
			Numeric,
			"Continuous",
			formula(
				Eval(
					Eval Expr(
						dt:Value[(:SerialNumber << get data table) << get rows where(
							dt:Base_value_norm == 1 & dt:SerialNumber == Expr( dt:SerialNumber[Row()] )
						)] / dt:Value
The problem is when I try to execute script I get the following error:
Invalid row number when accessing or evaluating "dt::SerialNumber[ /*###*/Row()]" , dt :: SerialNumber[/*###*/Row()].
But If I provide the formula manually after column is created it works as desired. What can be the reason why it is not working in script? I need to do that in script since several new columns need to be created in such a way. The data table with saved formula is attached.
Thank you and best regards
Re: Invalid row number when accessing or evaluating of column values
Am I missing something, or can you simplify the formula to
dt = :SerialNumber << get data table;
curSerialNumber = dt:SerialNumber;
dt:Value[dt << get rows where( dt:Base_value_norm == 1 & dt:SerialNumber == curSerialNumber )] / dt:Value;
lukasz
Hi Jim,
thank you for suggestion, works as desired.
Best regards.
