Buttinoni7
Graph Builder multiple page size
I need to plot multiple chart using page at bottom right field where I drag and drop the chartnum column with it's chart number (1 to 50 charts). My purpose is to plot individual chart for each page.
The problem is that instead of individual plotting it makes overlay multiple chartnum (grouping by each 9). Is it possible to change the page interval so I can plot individual chart for each page?
JMP15
Re: Graph Builder multiple page size
Try changing the Data Type of Chart number column? to Ordinal (or Nominal).
Buttinoni7
Nominal was the right setting. Thank you so much.
