Created:
Aug 1, 2022 01:20 AM
| Last Modified: Jun 8, 2023 2:10 PM(2371 views)
Hi All,
Within the DOE menu, if l select Sample Size Explorers - Confidence Intervals and Margin of Error for one Sample Variance, when i change the sample size the interval width changes, but what is the interval width telling me?
The confidence interval width represents the uncertainty in the estimate of the variance. A larger sample reduces the uncertainty and shrinks the width. A smaller sample increases the uncertainty and expands the width.
