sipho-ss
Finding value of column y at max value of column X
I want to find the maxium value in column "Power (dBm)" grouped by BarID, ChipID.
And use that to find the corresponding value in column "Wavelength (nm)" to give me a summary table showing the value of maxium power and what value of wavelngth it occurs at grouped by BarID, ChipID etc.
Re: Finding value of column y at max value of column X
Here is an example of doing a similar thing using the Big Class data table
dt =
// Open Data Table: big class.jmp
// → Data Table( "big class" )
Open( "$SAMPLE_DATA/big class.jmp" );
dt << select where(col max(:height,:sex) == :height );
dt << subset(selected rows(1), columns({"Sex","Height","Weight"}));
