BookmarkSubscribeRSS Feed
terapin
Jun 23, 2011
Interactively Change X-Axis Date Range
I was hoping to create a series of dynamic overlay plots in which the user could interactively change the starting and ending dates for the x-axis on all plots. Does anyone have any suggestions about how to create an interactive dialog for x-axis starting and ending dates that would then change the display range on all overlay plots?
Re: Interactively Change X-Axis Date Range
Have you tried using the Data Filter tool to set a range for date? If you have the Include option checked, the axes of the overlay plot should auto-scale based on the range of dates that you select.
terapin
Jun 23, 2011
I did try your suggestion and it works fine. I didn't realize this would work that way, but it certainly does what I want without having to write any code to do this. Thanks.
