‘New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit – register now, free of charge.
Installing JMP 17 Via powershell to include license
Hoping someone can help, I am trying to find a script that will install JMP 17 via network drive and also install the SID file and set the per file to a default location.
ih
Super User (Alumni) ih
Re: Installing JMP 17 Via powershell to include license
Hi @PoynomialMink80 , you could do this:
  • Reference this link to build a silent installation of JMP with your preferred preferences
  • In your script, copy the installation media to a local drive
  • Run the JMP install, you could include the license in the install and skip the next step but I find the next step makes it easier to renew the license in the future
  • Copy the license file to the machine and create a preferences file that references a specific license file location
#Load the License File
$LicenseFile = $InstallDir+"\jmp.per"
Copy-Item $SourceDir"\jmp.per" $LicenseFile -Force
# Create directories if needed
New-Item -Path $Env:ALLUSERSPROFILE"/SAS" -ItemType Directory -Force
New-Item -Path $Env:ALLUSERSPROFILE"/SAS/JMPPRO" -ItemType Directory -Force
New-Item -Path $Env:ALLUSERSPROFILE"/SAS/JMPPRO/17" -ItemType Directory -Force
$AddinDir = $Env:ALLUSERSPROFILE+"/SAS/JMPPRO/addins"
New-Item -Path $AddinDir -ItemType Directory -Force
# Create preferences file that links to the license file
$fn = $Env:ALLUSERSPROFILE+"/SAS/JMPPRO/17/JMP.PFS"
New-Item -Force $fn
Set-Content $fn "Preferences(
	File Location Settings(
		License File Path( $LicenseFile )
More info about installing the license and add-ins:
Anyone manage add-ins using a script or a centralized tool? Maybe a PowerShell script via Microsoft ...
Many thanks this is what I am looking for. Thank you
This scirpt is awesome! I'm deploying via intune / powershell and its exactly what I was looking for. One question, how are you updating yearly? Do you just need to delivery a new .per file to the machine and overwrite the old one? JMP's docs indicate a user-interactive procedure vs an ideal silent update.
My thinking is use intune to deliver a new per file and overwrite the old one, which is easy enough, but will JMP notice the new per file? I mean we can tell the users "yeah new per file's already there, just click it and go about your day" but that's less ideal
