  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
asj
asj
Input a single value to multiple selected cells in data table at once (excel CTRL+enter equivalent)
Hi all,
I was wondering if there is a good way to enter a single value (such as "1") into all cells which I have selected in a data table. In Excel you would do this by pressing CTRL+enter after setting the value for the cells.
The workaround I'm using is to write the value in notepad, select the value, copy it to clipboard and in JMP data table on top of selected cells click "paste". This just does not feel right.
My use case is labelling data groups: I have a visualization open in graph explorer. I select a population from the graph, and want to insert a population ID number onto a new column in the data table, then select another population and set its population ID and so on...
(using JMP 18).
Thanks for help!
Re: Input a single value to multiple selected cells in data table at once (excel CTRL+enter equivalent)
Name Selection in Column could be enough
You can also access it from right click on graph builder
I have also made a wish list item to make it more "useful" Allow Name Selection In Column be used for multiple selections
Jarmo's response is a good way to handle this.  I will many times use a different approach.  I place into the paste buffer the value I want repeated, then is I simply use CNTL/V  the paste buffer value will be copied to all selected cells.
asj
asj
Thanks @jthi - this answer (+ your add-in) is exactly what I was looking for!
BHarris
This, i.e. Name selection in column, is how I used to do it, but it's frustrating that the column name doesn't default to the current column, so I often end up having to retype the column name.  There should really be a button to copy in the name of the current column, or a default so it grabs the current column name.
Copying the value from somewhere, then selecting the cells and then "paste" is a new tip -- thanks, Byron!
Alternatively, recode "in place" is another method I use frequently for this.
Byron_JMP
I do this fairly often.
First copy the value you want to paste into the clipboard, (select the number, Ctrl+c to copy)
Then select all the places you want it to go and do Ctrl+v
Level XIII
If you have a specific list of labels, you could also use the wand tool in the QuickSelect Toolbar.
no need to find the data table ... just select the data points/rows, click on the wand icon and select the label from list - or use your own label:
another benefit: you can specify multiple labels for one and the same row :)
existing labels in the row will not be overwritten.
Name Selection in Column: could be my favorite tool :) if ...
