JZ
JZ
Standardization required in Multivariate?
I'm trying to perform an outlier analysis (Mahalanobis distance) in Multivariate. Do I need to standardize (normalize all values to the same scale, for example, -1 to 1) all values before executing the analysis, or does JMP do that for me automatically? Thanks.
statman
Re: Standardization required in Multivariate?
Here are my thoughts:
Multivariate is typically done on the Y's (response variables), not the x's.  Now that doesn't mean you can't do both.
The way Mahalanobis works is to relate the values in each column to the values in other columns over the data set.  The analysis evaluates, in general, are you getting values reasonably close enough to typical values when the other columns are their respective levels.  If not, perhaps something unusual happened during that row.  It is not specific as to which data points created the infraction.  Sometimes it's obvious which value was unusual, sometimes not.
In any case, standardization of the values is not necessary.
