tom_abramov
Level V
Independent Grouped X Scales in Graph Builder
I've just seen this Live Webcast "Using Design of Experiments to Increase Predictability, Optimise Processes and Minimise Costs".
One of the charts I saw was Graph Builder single chart with several X Scales (X Group) but each X Scale had its own min and max values.
Please see attached the image. In that image I would like that each Input will have its own independent X scale.
Now, when I saw it is possible, how do I do it? :)
Thank you.
pmroz
Re: Independent Grouped X Scales in Graph Builder
In JMP 13, in Graph Builder I dragged X1, X2 and X3 to the x axis, one at a time.  When I dragged X2 I dropped it into the zone at the lower right, not the center.  Same for X3.  This is my result:
Here's the corresponding JSL:
New Table( "Test", 	Add Rows( 4 ),
	New Script("Percent Reacted vs. X1 & 2 more",
		Graph Builder(Size( 486, 452 ),
			Show Control Panel( 0 ),
			Variables( X( :X1 ), X( :X2 ), X( :X3 ), Y( :Percent Reacted ) ),
			Elements( Position( 1, 1 ),
				Line( X, Y, Legend( 40 ) ),
				Points( X, Y, Legend( 43 ) ) ),
			Elements( Position( 2, 1 ),
				Line( X, Y, Legend( 41 ) ),
				Points( X, Y, Legend( 44 ) ) ),
			Elements( Position( 3, 1 ),
				Line( X, Y, Legend( 42 ) ),
				Points( X, Y, Legend( 45 ) ) )
	New Column( "X1", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [1, 2, 3, 4] )),
	New Column( "X2", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [44, 33, 22, 11] )),
	New Column( "X3", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [444, 333, 555, 666] )),
	New Column( "Percent Reacted", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [10, 20, 30, 20] ))
pmroz
