d_barnett
Open Image (jpg) Files, Perform Analysis and move onto next Image
I am very interested in using JMP to do automatic image processing and analysis and I have a script ( heavily based on John Pontes add-in - and information gathered from his excellent blog John Ponte, Author at JMP Blog)  that I can run on one image at a time on images but what I really want to do next is to create  a 'looping' script that does the following
  1. counts the number of .jpg files in a directory.
  2. one-by-one opens an image, puts the information available ( I'm using John Pontes Image analyser add-in and script for this) into a data table
  3. does a basic analysis ( mean of columns & rows etc.)
  4. saves this with the jpg filename
  5. closes the files down and moves onto the next image.
I have a number of small problems with this but the main ones are that when I use the following
For( i = 1, i <= N Items( files ), i++,
  If( Ends With( files[i], ".jpg" ),
  Open( files[i] );
the open ( files); opens the jpg files in another program ( the default prog that I don't want to change). How do I get it so that it opens up in JMP using the following ( or something else if it's better)
img = New Image( "thefilenameofthe.jpg" );
w = New Window( "image", img );
I can then perform the analysis and close this all down and loop back around until all of the images have been analysed.
[*Edit to original post by staff member sseligman. Second part of user question added here to original post.]
Many apologies, I wasn't clear enough in my original post. What I want to do is to put the pixel information into a data table, not the original image itself.
this is, in effect, automating the ImageToDatatable JSL script that has already been written but go through each image within a folder and save the resulting data table with any resultant analysis of the pixels in the same folder.
the x & y co-ordinates along with the RGB, I and HSL are sufficient for me to carry out any analysis I require. I have attached an example data table that I can perform analysis on, I have also attached the original image where this data was taken from, I have a few thousand of these which I need to go through so doing them one at a time would be nearly impossible.
apologies again for the bad wording and lack of clarity in the original post.
Regards
David
sseligman
Re: Open Image (jpg) Files, Perform Analysis and move onto next Image
Consolidating two replies to this post as the solution.
Part 1 from staffer @Craige_Hales:
path = "$desktop/temp/";
files = Files In Directory( path );
For( ifile = 1, ifile <= N Items( files ), ifile++,
  filename = files[ifile];
  If( Right( filename, 4 ) == ".jpg",
  pic = Open( path || filename, "jpg" );
  jslcolor = pic << getpixels();
  {red, green, blue} = Color To RGB( jslcolor );
  {hue, lightness, saturation} = Color To HLS( jslcolor );
  nr = N Rows( jslcolor );
  nc = N Cols( jslcolor );
  dt = New Table( Substr( filename, 1, Length( filename ) - 4 ),
  addrows( nr * nc ),
  New Column( "x" ),
  New Column( "y" ),
  New Column( "red", setvalues( red ) ),
  New Column( "green", setvalues( green ) ),
  New Column( "blue", setvalues( blue ) ),
  New Column( "hue", setvalues( hue ) ),
  New Column( "lightness", setvalues( lightness ) ),
  New Column( "saturation", setvalues( saturation ) ),
  irow = 0;
  For( iy = 1, iy <= nr, iy++,
  For( ix = 1, ix <= nc, ix++,
  irow++;
  dt:y[irow] = iy;
  dt:x[irow] = ix;
  // do something with dt
  Wait( 1 );
  Close( dt, "nosave" );
Part 2 from staffer @JohnPonte
One thing I'll suggest is that you can use NewImage(), instead of Open() for the image file. Open() is a more general function that has to figure out what you are opening. In that process, it uses OS functionality, like opening your image in another program. img = NewImage("filename.jpg"); will open the image file and create a JSL image, returning you the handle to it.
The other suggestion is that you can use another script I did (before the Image Analyzer) on the File Exchange, called ImageToDatatable. It will convert your image into a data table, similarly to the Image Analyzer, but you won't get all the rest of what the Image Analyzer does.
Wrap that in the loop as @Craige_Hales shows (above) and you should be good to go.
6 REPLIES 6
ian_jmp
Level X
This should put the image files in a folder into a JMP table:
// ian.cox@jmp.com:23Jun2014
dir = Pick Directory("Pick a directory containing image files:");
fList = FilesInDirectory(dir);
if (NItems(fList) < 1, Print("No files found in folder "||dir||"."); Beep(); Throw());
dt = NewTable("Images from "||dir,
NewColumn("File Path", Character, Nominal),
NewColumn("Image", Expression), AddRows(NItems(fList))
for (f=1, f<=Nitems(fList), f++,
fp = dir||"/"||fList[f];
Column(dt, "File Path")[f] = fp;
Try(Column(dt, "Image")[f] = NewImage(fp)); // Use 'Try()' in case it's not an image file
Craige_Hales
add the file type parameter.  then the returned value will be a picture object.  It will probably work even if you mix and match PNG, JPG, GIF; it tells JMP to return the picture rather than falling back on the OS default program for the extension.
open("$desktop/setFont.PNG","PNG")
New Image(
  Char To Blob(
  "640745eJxkugdUU0v3PgyCIFKiotKDCsL10ovUEFBQRJodKQJKLyF0gpSIKIjSpEgnCgoqVVrooRk6obcACUaaG...
or use newimage to get the picture object.
newimage("$desktop/setFont.PNG")
New Image(
  Char To Blob(
newimage is simpler; open might be needed if the image is a URL or Blob.
Craige
d_barnett
David.
Craige_Hales
  addrows( nr * nc ),
  New Column( "x" ),
  New Column( "y" ),
  irow = 0;
  irow++;
  dt:y[irow] = iy;
  dt:x[irow] = ix;
  Wait( 1 );
Craige
JohnPonte
Staff (Retired)
I just came across this post and thought I'd add a couple of points, in case it is still helpful.
Wrap that in the loop as Craige@JMP shows (above) and you should be good to go.
sseligman
  addrows( nr * nc ),
  New Column( "x" ),
  New Column( "y" ),
  irow = 0;
  irow++;
  dt:y[irow] = iy;
  dt:x[irow] = ix;
  Wait( 1 );
