BookmarkSubscribeRSS Feed
BSwid
Contributor
Sep 25, 2018
Importing data from Excel, remove subtotal lines
When importing from data sources often the source data contains a subtotals by category.  Is there a good way to remove these subtotals after import with a JMP function or some script?  Or is there a way to remove these subtotals during import?  Thank you.
BSwid
Contributor
Sep 25, 2018
Solution
Re: Importing data from Excel, remove subtotal lines
Answer Found here:
https://community.jmp.com/t5/Discussions/How-to-delete-rows-based-upon-a-condition/td-p/52999
Update the code for when :"Product Line" =="Subtotal"
BSwid
Contributor
Sep 25, 2018
Solution
Answer Found here:
