BookmarkSubscribeRSS Feed
Importing column properties for multiple columns from excel spreadsheet
How do I import column properties for multiple columns of data from an excel spreadsheet?  I'm looking at measurement data for a large number of manufactured features and need to calculatge process capability for each column of data where each column has a different LSL and USL.  I have the measurement data and spec limits in an excel spreadsheet.  I could manually enter spec limits for each column, but I'm sure there is an easier way to do this.
David_Burnham
Jul 13, 2011
The capability platform (under the graphs menu) allows you to import column specifications
-Dave
toddt
Community Member
Oct 14, 2011
I tried to import spec limits using the "Get Limits" option in the control charts dialog but it doesn't seem to work. The limits file looks to be properly formatted according to the information in JMP help, see the example below.  I get an error (No matching columns in Limits File) and it immediately kicks me into a spec limits entry dialog.
Column 1      _LSL     _Target     _USL
testA               0                             1
testB               2                             3
The testA and testB values match column headings in the original table.  I've tried spec limits files in both orientations to no avail.
jb
Sep 23, 2015
Re: Importing column properties for multiple columns from excel spreadsheet
With Control Charts, you may need to separate measures into individual columns.
Did you try using Tables>Split to reformat your spec limits?
_LimitsKey   A    B
_LCL         0    2
_Avg
_UCL         1    3
This arrangement works for me.
