The column's units are not part of the column name. They are a separate column property, called "Units". What you need to do, is to go to the newly created data table. Then right click on the column header and select
Column Properties==>Units
Type the units into the dialog box that is displayed, and then click on OK.
The Units will then be displayed at the end of the Column Label
