David_Burnham
Deleting Objects in v15
In JSL I can define a class and use it as a template to instantiate objects.
How do I delete the object?
I've been using the message deleteClass, assuming its a slight misnomer and really it's deleting the object.
But in version 15 it really does seem to delete the class.  Once I use the message I'm unable to create any further instances of the class.
I can use a delete message but I think its just an alias for deleteClass and I have the same problem.
Is delete class really intended to wipe out the entire class definition?  If so, what is the correct way of deleting the object?
Here is a simple test script:
names default to here(1);
defineClass("MyClass",{
	_value = .,
	_init_ = method({value},
		_value = value;
	getValue = method({},
		return(_value)
// this works
obj = newObject( MyClass( 10 ) );
show(obj:getvalue);
// this works
obj = newObject( MyClass( 20 ) );
show(obj:getvalue);
// there should be no harm deleting
// an object once I am finished with it
obj<<delete;
// but this now fails ...
obj = newObject( MyClass( 30 ) );
show(obj:getvalue);
-Dave
Craige_Hales
Re: Deleting Objects in v15
I don't understand how to use it either. I think you don't need it:
Define Class(
	"aa",
	{_init_ = Method( {a}, this:b = a ), //
	x=1, //
	m1 = Method( {a, b}, a * b )}
lcaa42 = New Object( aa(42) );
lcaa42:x= Run Program(//
		Executable( "PING.EXE" ), //
		Options( {"-n 50", "localhost"} ), //
		ReadFunction(
			Function( {this},
				write(this << read);
wait(5); // report about 5 of the 50 pings to the log
// this will destroy the old object and replace it with a
// new one. The log will report the RunProgram object was
// destroyed; there may be a more clever way to witness the
// destruction...best I could come up with...
lcaa42 = New Object( aa(42.1) ); // the old one is gone
lcaa43 = New Object( aa(43) ); // the class still works
show(lcaa42:b,lcaa43:b); // 42.1,43
Show Classes();
Pinging v1-PC [::1] with 32 bytes of data:
Reply from ::1: time<1ms
The external program was producing output when the RunProgram object was destroyed.
Use a JSL variable to hold the RunProgram object.
Optionally, send messages to the variable to manage the object's lifetime.
lcaa42:b = 42.1;
lcaa43:b = 43;
// Class aa
_init_ = Method( {a}, this:b = a );
m1 = Method( {a, b}, a * b );
x = 1;
This shows the first object was deleted by assigning a new value to the variable holding it.
If other variables are copied (not cloned)
lcaa42b=lcaa42;
then all the copies must be cleared to destroy the object.
lcaa42b=0;
lcaa42=0;
@EvanMcCorkle
Craige
pmroz
Does this work: obj = .;
David_Burnham
I don't know.
Before it was possible to "define classes" I created them using namespaces.
For namespaces this doesn't work i.e. setting the variable to missing is not the same as deleting the namespace.
ns = newNamespace("xyz");
ns:a = 10;
ns = .;
show namespaces();
-Dave
Craige_Hales
Define Class(
	"aa",
	x=1, //
		ReadFunction(
			Function( {this},
Show Classes();
lcaa42:b = 42.1;
lcaa43:b = 43;
// Class aa
x = 1;
lcaa42b=lcaa42;
lcaa42b=0;
lcaa42=0;
@EvanMcCorkle
Craige
vince_faller
It seems like it's overwriting it if you just overwrite the variable.  I ran
Define Class(
	"Test",
	nObs = 20;
	addition = Method( {x, y},
		(x + y) * nObs
	append = Method( {a, b},
		Char( a ) || " + " || Char( b )
for(i=1, i<=1000000, i++,
	clref = New Object( Test() );
delete symbols(clref);
While looking at the memory usage of JMP and it didn't really move.  I would expect if it wasn't actually overwriting it I'd see memory go up if I have a million of them.
Vince Faller - Predictum
David_Burnham
Thanks everyone, I think the evidence if clear that reassigning an object variable destroys the object rather than leaving it as an orphan in memory,
-Dave
