Datamom1
If statement Formula not working
For the past couple years when I copy and paste the formula below it has not worked consistently.  I've tried typing it in the formula box and have at times been succesful but it's not consistent.
I was finally upgraded to JMP 14 last week and an option that is awesome is that I can preview a data sample to see what the formula result will look like.  However, I can't figure out why this formula won't work.  Below is a screenshot of the formula as well as the preview of the dataset and formula result.
Are there any suggestions?
Re: If statement Formula not working
The data looks to be left justified in the preview.  Is the data type set to character for the Behavioral - physical aggression to staff column?  If so, you will need to add double-quotes around the number on the right side of the == operator or change the data type of the column.
Wendy
A possible issue may be that JMP may be having an issue with
Behaviorial - physical aggression to staff
Is this a calculation of a column or variable called
     Behavioral
from which is subtracted a column or variable called
or
is this a single column or variable called
JMP can get confused over this.  If it is one column and not a calculation, you should actually state the formula as
If( :Name("Behavioral - physical aggression to staff") == 1,
     1,
     0
The JMP formula editor will not display the :Name() function, but by you putting into your formula, it will make sure JMP understands what you are specifying.
Craige_Hales
Also, if the 1s in the table were calculated, they might not be exactly 1 (which is what you are testing for). The table displays a value that is rounded to about 10 digits. Try
Round(:Name("Behavioral - physical aggression to staff"), 5) == 1
and see if that works better.
Craige
Craige_Hales
@ErnestPasour for the awesome comment!
Craige
Wendy
Datamom1
Thank you very much!  That worked perfectly! This will save me a lot of time.
