BookmarkSubscribeRSS Feed
kwmcm
New Contributor
Aug 6, 2018
If/Then scripting
Hi group, I'm hoping someone out there can help!
I'm looking for a piece of coding to help with some if/then filtering.
In the attached data table, there are various lot numbers with multiple SampleID's, of different "flavors".
The goal is this:
If the LOT# is the first instance, then it will be selected. If the next row is the same, it'll skip it, and continue skipping until it sees a new LOT#.
That new first instance of the next LOT# will be selected. And continuing on.
I'd then like those selected rows to be subsetted into a new data table.
I'm hoping someone knows if this is possible. JMP can do anything, so I'm sure it is, I just don't know how.
Thanks so much!
mwechtal
Community Trekker
Jan 19, 2012
Solution
Re: If/Then scripting
It first needs to be sorted by LOT#, but you have that. So the code is:
dt << (select where( :LOT# != Lag( LOT# ) ));
dt << subset( selected rows( 1 ), selected columns only( 0 ) );
The Lag function looks at the value from the previous observation.
Jun 22, 2012
Solution
If I am understanding your question, and if your lots are located all together, then this code will work
dt << select where( :name( "LOT#" )[Row()] != Lag( :name( "LOT#" )[Row()] ) );
dtNew = dt << subset( selected columns( 0 ), selected rows( 1 ) );
mwechtal
Community Trekker
Jan 19, 2012
Solution
Jun 22, 2012
Solution
kwmcm
New Contributor
Aug 6, 2018
YES! this is exactly what I was looking for!
Thank you!
uday_guntupalli
Community Trekker
Sep 15, 2014
@kwmcm
       Maybe something like this
dt << Sort(By(:LOT#),Order(Ascending),Replace Table(1));
// Get Lot #
LotNums = dt:LOT# << Get Values;
// Get Unique Lot #
UniqueLotNums = Associative Array(LotNums) << Get Keys;
// Define List and new column values
SaveList = [];
// Find first occurence
for(i = 1, i <= N Items(UniqueLotNums), i++,
		SR = dt << Select Where(:LOT# == UniqueLotNums[i]) << Get Selected Rows;
		dt << Clear Select ;
		SaveList = SaveList || SR[1];
// New Column
NewCol = As List(J(N Rows(dt),1,"0"));
NewCol[SaveList,0] = LotNums[SaveList];
dt << New Column("test",character,nominal,<< Set values(NewCol));
Best
Uday
