David_Burnham
Identifying Titles of Graph Builder Page Titles
In the following graph, I want to be able to identify the page titles:
i.e. "sex = F" and "sex = M".
Looking at the display tree it would appear that the titles are associated with a display box of type GraphBuilderGroupBox:
I have the following script:
Open("$SAMPLE_DATA/Big Class.jmp");
gb = Graph Builder(
	Size( 378, 714 ),
	Show Legend( 0 ),
	Variables( X( :height ), Y( :weight ), Page( :sex ) ),
	Elements( Points( X, Y, Legend( 8 ) ), Smoother( X, Y, Legend( 9 ) ) )
rep = gb << report;
lst = rep << xpath("//GraphBuilderGroupBox");
for (i=1,i<=nitems(lst),i++,
	title = lst[i] << get text;
Unfortunately this doesn't work (title = "" for both pages).
Does anyone have any suggestions?
Thanks,
David
-Dave
Re: Identifying Titles of Graph Builder Page Titles
Wow! That is one uncooperative box! Try using rep<<getJournal and hunting for LabelBox(label(\!"sex = F\!") stuff. At least in JMP 16, for the simple big class example, the LabelBoxes in the journal and the GraphBuilderGroupBoxes  seem to run in parallel.
@XanGreggthe box in question transforms itself into something friendlier when journaled. But in isolation, in the live graph builder, it won't say anything about itself.
This is one element I havent figured out how to directly access with Report layer or Xpath //GraphBuilderGroupBox << Get Window Title issue . Not sure if they could be built somehow using Get Variables
gb = Graph Builder(
	Size( 378, 714 ),
	Show Legend( 0 ),
gbb = Report(gb)[Graph Builder Box(1)];
Show(gbb << get variables);
Show(gbb << get variable(1));
David_Burnham
Thanks @Craige_Hales  - looks like this will be a workable solution.
-Dave
ih
Super User (Alumni) ih
For page, group, and wrap variables you can set a column property defining the value order and then use that to be sure of which plot is which.  I often want to change the column or level names anyway and now this can all be done in a transform column:
pageOrder = {"Female", "Male"};
Eval( Eval Expr(
	gb = Graph Builder(
		Size( 378, 714 ),
		Show Legend( 0 ),
		Variables(
			X( :height ),
			Y( :weight ),
			Page( Transform Column( "Respondent Sex", Nominal, Set Property("Value Order", {Custom Order( Expr( pageOrder ))}), Formula( if(:sex=="M", "Male", "Female" ) ) ) )
Side note: The GraphBuilderGroupBox you referenced probably does not contain that text, note that if you set the visibility to hidden the heading is still there. I think this element just doesn't show up in the tree, sort of like how individual points aren't in there.  It would be nice if both were accessible!
David_Burnham
Thanks for that suggestion @ih . The specific reason for wanting to get the titles of the pages is that I don't know ahead of time the list of potential values (i.e. pageOrder in this example).  In the real-world example the chart has over 400 pages (don't ask me why anyone wants a chart that size!) and the number of pages changes in reason to a local data filter.  If all else fails I will go back to trying to build that list - for my initial attempt my list contained about 460 elements and the graph only had 407 pages - perhaps some combinations were being excluded due to missing data - I've not investigated that yet - still trying to find the path of least resistance!
-Dave
