EH1
EH1
IDENTIFY LARGEST 3 VALUES TO CREATE INDICATOR COLUMNS
I'm a trying to compare across column values (Utility A to Utility E) to identify the largest 3 values and put the results into indicator columns ("Top 3 - A" to "Top 3 - E").  So, if "Utility A" is one of the largest 3 values in the row, "Top 3 - A" would receive a "1".  If the value is NOT one of the 3 largest in the row, "Top 3 - A" would receive a "0".
I tried using "Match", but wasn't able to get it to work.  Appreciate any help folks could provide!
Re: IDENTIFY LARGEST 3 VALUES TO CREATE INDICATOR COLUMNS
Here is a formula that will work.  Just change the comparison column from A to B to etc.
If(
	:"Utility - A"n >= Sort Descending(
		Matrix( :"Utility - A"n ) || Matrix( :"Utility - B"n ) || Matrix( :"Utility - C"n ) ||
		Matrix( :"Utility - D"n ) || Matrix( :"Utility - E"n )
	)[3],
	1,
	0
If(
	)[3],
	1,
	0
EH1
EH1
Thank you so much, Txnelson!  This is exactly what I needed!  I greatly appreciate you taking the time to share your expertise!!
