The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
JaneYang
How to show the actual range in the level values in Graph Builder?
2021-11-29 10_52_16-Untitled 18 - Graph Builder - JMP.pngHi,
In the attached plot, the property of column "ChannelNumber" is Numeric/Continuous. I found it confusing in the grouped values at the top. "0-4" actually includes 0-3, as shown at the bottom; "4-8" actualy includes 4-7. It seems the range at the top always has overlapping values between adjacent levels. What can I do to make this overlap go away (i.e. I want it to show "0-3", "4-7","8-11" at the top)? Thank you very much...
13 REPLIES 13
frank_wang
Re: How to show the actual range in the level values in Graph Builder?
Hi Jane
增加一个新的列,将你原先的信道归纳到这3个分类里。(0~3,4~7,8~11)
用新增的列作为X group即可实现你的需求。
心若止水
JaneYang
Thank you Frank. I wonder if there is a way other than adding a new column...
If you have JMP16, you could create Custom Range:
Or in this case it might be enough if you just change the Bin Label Style from Cutpoints red triangle in same Custom Levels menu.
Default:
Using Low to high - 1
JaneYang
Thanks, but I am using JMP14. There is no "Custom Levels" option. The closest I can get it to add a Binning column:
Any other ideas please?
Just wanted to point out that if the value is continuous, then what happens if you have a value of 3.9? What about 3.999999? The default is that the intervals are left inclusive. Mathematically it would be written as [0,4), [4,8), etc..
It sounds like you might want to consider the data as ordinal if the fractions are not possible.
Dan Obermiller
JaneYang
Thanks, Dan. I tried that too. This is what I got after setting it to ordinal:
ian_jmp
Level X
Unfortunately, I don't have JMP 14 to hand to check - But if you right click on 'ChannelNumber' in the Graph Builder display immediately above, do you see some options that allow you to control the number of levels displayed?
I do have version 14. If you right-click on the channel number, select Number of Levels. From your first example, that would be 12 levels. Not sure why yours defaulted to 3 levels as mine defaulted to all levels.
I made a simple example, and it looks like this (as a scatterplot rather than boxplot).
Dan Obermiller
JaneYang
Thanks Dan. I was trying to make the ChannelNumber into 3 equal groups, as in 0-3, 4-7, 8-11. Number of Levels to display was set to 3. My original question was how to make it show "0-3","4-7","8-11" at the top, instead of "0-4","4-8","8-11", without adding another column.
