SpannerHead
I want to use a value in a numeric column to create a reference to the same column number
I generated a column with integers that I now want to use to reference values in columns of the same number.  Column 9 contains the number indicating which column should be referenced by a formula in Column 10.  Below are several things that don't work.
Slán
SpannerHead
Level XIII
Re: I want to use a value in a numeric column to create a reference to the same column number
Which error message is displayed when you hover over the code with the red underline?
Names Default to Here(1);
New Column( "Column 9",
	Numeric,
	Set Values( [1, 2, 3, 4, 5] )
New Column( "Column 10",
	Expression,
	Formula( Try( Column( :Column 9 ) ) )
no error:
If you don't want to retrieve the columns - but the value stored in the columns,  use As column() instead of column():
robust column reference
... or add a row index to Column():
  Column(col)[row()]
or          Column(col)[]
New Column( "Column 10b",
	Character,
	Formula( Try( Char( Column( :Column 9 )[Row()] ) ) )
Besides that,
  • please ensure that the calculated value matches the modelling type of the column.
    Columns 1 to 5 contain numbers and characters. This is why I added Char().
  • Column(.) will fail and the column formula will terminate. So please check if there are missing indices in Column 9
Level XIII
	Numeric,
	Expression,
no error:
  Column(col)[row()]
or          Column(col)[]
	Character,
Besides that,
SpannerHead
Thanks but those just give me the value already in Column 9, I want to look up the value of a different column as enumerated in Column 9 if that makes sense?
Slán
SpannerHead
Level XIII
combining both approaches, let's retrieve the columns in the first step - and the values in the second step:
New Column( "column",
	Expression,
	Formula( Try( Column( Row() ), . ) ),
New Column( "value",
	Character,
	Formula( Try( Char( :column[Row()][Row()] ), "" ) ),
why :column[Row()][Row()]?
:column is column #9,
:column[row()] is the entry in the specific row of this column, e.g. Column ("sex")
and :column[row()][row()] is  the entry in the specific row of e.g. Column ("sex")
SpannerHead
Great addition!  No good deed and all that.............
I now need to iteratively operate on every column relative to the maximum value stored in Column 9.  The normal addition of the value of i doesn't naturally apply in this case.
clear symbols();
lim = Col Max(Column(8));
For (i=1, i<=lim, i++,
	Character,
Slán
SpannerHead
Level XIII
A very common issue:
a variable defined outside of the new column message - and used inside the new column message:
-> Expression Handling in JMP: Tips and Trapdoors
The solution: look up the variable and use the stored value:
For each  ({i}, 1::5,
Eval(Eval Expr(New Column( "col_"||char(i),
	Character,
	Formula( Try( Char( Column( Expr(i) )[Row()] ) ) )
more robust:
	Character,
	Formula( Try( Char( Expr(Name Expr(As Column( i )) )) ) )
From the first day I saw it in one of @jthi's posts, I admired the Name Expr(As Column(col)) and used it wherever I could.
With the learning from  https://community.jmp.com/t5/Discussions/Using-numeric-objects-in-a-column-equation/m-p/903966/highl... , I am really happy that this approach has helped me avoid many pitfalls.
As Column(col) or Column(col) in a column formula? Too fragile!
