Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
I have a table with several columns with values that represent total votes obtained by political parties. I need a script that finds the greatest values of these columns and obtains the name of the column, i.e. the political party.
The Match() function is under the Conditionals section of the Formula Editor.
With the Maximum() funtion built and selected in the Editor, click on Conditionals -> Match. You'll be prompted about adding arguments, select "Do Not Add".
Then click on the ^ button in the toolbar to add the four pairs of arguments and then fill them in.
