miguello
Community Trekker
How to work with checkboxes?
In my application on the launch window I have a set of checkboxes. They will define, pretty much, what steps of data cleaning will be performed with the table.
So I need pretty much to get the status of each checkbox and then run a corresponding function on each checkbox that is checked.
Manuals are pretty much useless, the only thing I got was that I can get a list of strings with the names of checkboxes that are selected.
cb << Get Selected()
Is there a snippet that pretty much gets that list and outputs flags (variables that are either 0 or 1 that I can use in IF statements)?
Is there any other way to parse the checkboxes into flags and run corresponding scripts?
pmroz
Re: How to work with checkboxes?
This should get you started.
check_list = {"One", "Two", "Three", "Four"};
todo_list  = {};
nw = new window("Checkboxes", << modal(),
     my_cb = checkbox(check_list),
     panelbox("Actions",
           hlistbox(
                button box("OK",
                     keep_going = 1;
                     todo_list = my_cb << get selected;
                button box("Cancel", keep_going = 0)
nt = nitems(todo_list);
if (keep_going & nt > 0,
     for (i = 1, i <= nt, i++,
           if (todo_list[i] == "One",
//              Call function for One step
                print("One");
                todo_list[i] == "Two",
//              Call function for Two step
                print("Two");
                todo_list[i] == "Three",
//              Call function for Three step
                print("Three");
                todo_list[i] == "Four",
                print("Four");
I will point you to:
    Help==>Scripting Index
There, when you scroll down to:
     CheckBoxBox
and click on it, you will get all of the items that you can ask for, or pass to a check box, along with examples(code snipppets) for each
miguello
Community Trekker
Yep, I agree - this was the best place to look.
I ended up implementing it through Get, with only few options that was reasonable enough.
With more options the answer below should work.
The primary reason I was asking was that it is probably the most common way of using checkboxes and I did not want to "invent bicycle", but use the common code snippet to work with checkboxes.
pmroz
todo_list  = {};
     panelbox("Actions",
           hlistbox(
                button box("OK",
                     keep_going = 1;
                print("One");
                print("Two");
                print("Three");
                print("Four");
miguello
Community Trekker
Thanks a lot!
That, I assume, is the standard way of parsing checkboxes?
pmroz
That's one way of doing it.  It looks like the only way to see what's selected is with
cb << get selected
or
cb << get(index)
The get method requires a bit more work than get selected, which returns all selected values into one list for further processing.
