Neo
Neo
How to use Filter Change Handler to work with Page option in Graph Builder?
Attached is an example data table. The script below tries to plot each parameter selected via the Local Data Filter in a new "Page" in Graph Builder. As it stands, the y-axis title is shown as "Median" every time a new "Parameter" is selected via the Local Data Filter.
I would like the Parameter name to be the y-axis title when new a parameter gets selected and plotted on a new "Page".
I tried using the filter change handler for this, but my script does not quite work. I think I need the index i below to be updated each time a new parameter is selected or may be there is another way. Any direction will be useful.
XPath( "//TextEditBox" ))[i]
here is my script
Names Default To Here (1);
Clear Log ();
gb = Graph Builder(
	Size( 531, 325 ),
	Variables( X( :PartID ), Y( :Median ), Page( :Parameter ), Color( :TestStage ) ),
	Elements( Points( X, Y, Legend( 34 ) ) ),
	Local Data Filter(
		Conditional,
		Add Filter(
			columns( :TestStage, :Parameter ),
			Where( :TestStage == {"A", "B"} ),
			Where( :Parameter == {"BKDVoltage", "Capacitance"} )
	SendToReport( Dispatch( {}, "graph title", TextEditBox, {Set Text( "myTitleGoesHere" )} ) )
ldf = Current Report()["Local Data Filter"] << get scriptable object;
changeTitle = Function( {this},
	print(this);
  	ldfText = Regex(ldf << get where clause(),"\(?\s*(:Parameter == .*?)\)","\1");
	if(ismissing(ldfText),ldfText = " Selected Test Parameter ");
	(Report( gb ) << XPath( "//TextEditBox" ))[6] << Set Text(ldfText);
fsh = ldf << Make Filter Change Handler(changeTitle());
30 REPLIES 30
Neo
Neo
Re: How to use Filter Change Handler to work with Page option in Graph Builder?
@jthi Thanks, I tried to see which rows are getting filtered and the script partially works with the data table exampleSummaryTableNoLimsNew.jmp, but not in all filtering cases.
I am trying to select the filtered rows in the data table and manually check if they are correct. Currently I am stuck.
Clearly its my lack of understanding of the code flow which is preventing me to debug further so I would request some more help.
Modified script below (line 28 is where I check with get filtered rows).
clear log ();
gb = dt << Graph Builder(
    Size( 571, 174 ),
	Show Control Panel(0),
	Variables(X(:PartID), Y(:Median), Page(:Parameter), Color(:TestStage)),
	Elements(Points(X, Y, Legend(34))),
	SendToReport(Dispatch({}, "graph title", TextEditBox, {Set Text("Trend Chart")}))
ldf = gb<<Local Data Filter(
		Conditional,
		Add Filter(
			columns(:TestDate, :Has Limits?, :TestStage, :Parameter ),
			Where( :Has Limits? == "Yes" ),
			Where( :TestStage == "STG5" ),
Summarize(dt, uniq_params = By(:Parameter));
update_title = Function({this},
	param_where = Regex(local_filter << get where clause(), "\(?\s*(:Parameter == .*?)\)", "\1");
	fr = ldf << get filtered rows; dt<< select rows (fr);
	If(Is Missing(param_where),
		param_list = uniq_params,
		param_where_list = Words(param_where, "|");
		param_list = Transform Each({where_str}, param_where_list,
			title = Trim Whitespace(Word(-1, where_str, "="));
			Substitute(title, "\!"", "");
	tebs = Report(gb) << XPath("//GraphBuilderTitleBox/TextEditBox");
	y_tebs = tebs[4 :: N Items(tebs) :: 2]; // skip title, subtitle and xaxis?
	If(N Items(y_tebs) != N Items(param_list),
		Return(0); // some problem
	gb << inval;
	For Each({param_val, idx}, param_list, y_tebs[idx] << Set Text(param_val));
	gb << update window;
	Return(1);
local_filter = Current Report()["Local Data Filter"] << get scriptable object;
update_title(local_filter);
filter_handler = local_filter << Make Filter Change Handler(update_title());
Using data table subscripting is one option
dt = Open("$SAMPLE_DATA/Cities.jmp");
obj = dt << Data Filter(
	Add Filter(columns(:Region, :POP)),
	Mode(Select(0), Show(0), Include(1))
Summarize(dt, all_states = By(:State));
show(all_states);
// Change filter value at this point and run the code below
cur_rows = obj << Get Filtered Rows;
visible_states = Associative Array(dt[cur_rows, "State"]) << get keys;
Show(N Items(all_states), N Items(visible_states));
Neo
Neo
@jthi using my data table exampleSummaryTableNoLimsNew.jmp, the following appears to work as expected (I have manually checked the data table and outputs). How does one proceed from this to my actual problem where the data filter is within the Graph Builder. I find associative arrays very confusing so requesting some help here.
clear log ();
obj = dt << Data Filter(Conditional,
	       Add Filter(columns(:TestDate, :Has Limits?, :TestStage, :Parameter) ),
Summarize(dt, all_Parameters = By(:Parameter));
show(all_Parameters);
visible_Parameters = Associative Array(dt[cur_rows, "Parameter"]) << get keys;
Show(N Items(all_Parameters), N Items(visible_Parameters));
Keep with the simple JMP Sample Data and solve your problems one by one. First you have to define your problems. I skip quite a few problems you have to solve (or have already solved) to get this working and try to get focus on the current issue:
  • On top level you want to be able to figure out how to update Y-axis titles based on the Page name
  • You have filters which affect which pages are visible
  • You can have filter set to all, one, many and none
  • All and none are basically the same (all pages are visible) but they need to be managed in separate manner
  • How can you handle the these different situations; All, None, One and Many?
  • How can you handle these situations inside a function used in filter change hander?
Until you get this issue solved, there is no point moving to the full application you have (if you get stuck, you could solve some separate problem first if you have them). Below is example script, you should be able to get the else statement to always return 41 (or rather full list of states if you remove N Items()).
	Size(630, 590),
	Include Missing Categories(1),
	Variables(X(:State)),
	Elements(Treemap(X, Legend(4))),
	Local Data Filter(
		Conditional,
		Add Filter(columns(:Region, :POP), Display(:Region, N Items(6)))
show(N Items(all_states));
filter_ref = (Report(gb) << top parent)[OutlineBox("Local Data Filter")] << Get Scriptable Object;
get_selected_states = function({a},
	cur_rows = filter_ref << Get Filtered Rows;
	If(!Is Empty(cur_rows),
		Show(N Items(visible_states));
		Show("Empty..."); // Your problem, you should have all states visible here
get_selected_states(1);
f = filter_ref << Make Filter Change Handler(get_selected_states);
Neo
Neo
@jthi Thanks. Your last script works when I run it and results are as expected with JMP Sample Data (true for all your scripts so far). The reason I used  my data table is because I thought the data form I have could be causing my issue.
I am afraid, I am a bit lost now with all the different scripts on the table.
If it works with JMP Sample Data then you move to the most simple possible example with your own data
dt = Open("$DOWNLOADS/exampleSummaryTableNoLimsNew.jmp");
    Size( 571, 174 ),
filter_ref = gb << Local Data Filter(
	Conditional,
	Add Filter(
		columns(:TestDate, :Has Limits?, :TestStage, :Parameter),
Summarize(dt, all_params = By(:Parameter));
get_selected_parameters = function({a},
		visible_parameters = Associative Array(dt[cur_rows, "Parameter"]) << get keys;
		Show(N Items(visible_parameters));
get_selected_parameters(1);
f = filter_ref << Make Filter Change Handler(get_selected_parameters);
These counts should always match
Neo
Neo
@jthi I think, I get the same. Please see below.
Is the next task to introduce the function to change the y-axis title on each new page?
(Seems like your previous way of doing this would need to change now)
If you didn't do any modifications to my script, there is still one situation which isn't solved
If you go from a single selection to none / clear selections. That should be solved first
Neo
Neo
@jthi Thanks, I thought I had checked by unchecking all, apparently not. I get the same as you.
(Just checked, this issue seems to be there in your previous script as well, i.e. unchecking all does not result in expected output)
What is returned can be a bit finicky in my experience (especially when nothing/everything is selected). Next you would have to figure out what to do in those situations and then you should be able to modify my earlier script.
Below are few solutions to this whole thing which do work for me, not sure if the "simpler" one does work in JMP16. I wouldn't suggest looking into these until you have managed to figure out what you could do int the "Empty" situation so you understand what type of issues there could be.
View more...
    Size( 571, 174 ),
	Conditional,
	Add Filter(
	, // else, this wasn't solved
		visible_parameters = all_params;
	If(N Items(y_tebs) != N Items(visible_parameters),
	gb << inval;
	For Each({param_val, idx}, visible_parameters, y_tebs[idx] << Set Text(param_val));
	Return(1);
    Size( 571, 174 ),
	Conditional,
	Add Filter(
	gb << inval;
	page_texts = Report(gb) << XPath("//GraphBuilderGroupBox/text()"); // Not sure if this can be used in JMP16
	For Each({page_text, idx}, page_texts,
		y_tebs[idx] << Set Text(Word(-1, page_text, "="));
	wait(0);
	Return(1);
