JaneYang
How to show the actual range in the level values in Graph Builder?
2021-11-29 10_52_16-Untitled 18 - Graph Builder - JMP.pngHi,
In the attached plot, the property of column "ChannelNumber" is Numeric/Continuous. I found it confusing in the grouped values at the top. "0-4" actually includes 0-3, as shown at the bottom; "4-8" actualy includes 4-7. It seems the range at the top always has overlapping values between adjacent levels. What can I do to make this overlap go away (i.e. I want it to show "0-3", "4-7","8-11" at the top)? Thank you very much...
13 REPLIES 13
Level XIII
Re: How to show the actual range in the level values in Graph Builder?
What a wonderful feature: custom labels !
I tried to reproduce the steps in the screenshots with Jmp 17.1.0 - but once I change something in the binning scheme or the Bin Label Style, the displayed labels switch to "single number only" - independent of the  Bin Label Style settings.
This is how it looks after pressing "OK" and opening the menu again:
Level XIII
Jmp support confirmed that this is a known bug in Jmp 17.1 - th same if you try to use custom labels:
According to the settings on the left, it should be "low" and "high" but in the plot actually it is "64" and "100":
Level XIII
Workaround at the moment:
"save" the user define binning as a Transform Column and use that column.
the disadvantage: the user loses the ability to adjust the settings via Right Click/ Custom Labels ...
Level XIII
Seems to be fixed in Jmp 17.2
